xperia l battery draining within 2 hours
mill13
have been using sony xperia l since last september without any problems.  last friday it started to drain battery rapidly - full charge of 100% is gone within 2 hours.  any clue how to fix, did factory reset but still draining rapidly.
4 REPLIES 4
profile.country.RO.title
_alexdon_
Boot your phone in safe mode,see if anything changes:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
Jake-SonyXperia
Hi mill13,
In this situation, I can advise that this is likely related to a software issue, I suggest that you run a software repair on the handset to resolve this issue.
PC Companion
To repair the phone software
1.     Install PC Companion on a Windows PC from Support
2.     In PC Companion, under Support Zone and click Start.
3.     Under Phone Software Update, click Start.
4.     Click repair phone.
5.     Follow the on-screen instructions.
I hope this helps.
What are your thoughts about this forum? Let us know by doing this short survey.
mill13
Still have the same probem.  Took it back to the vodafone shop who sent it off to be repaired - was gone 4 weeks, got it back yesterday and still have same problem (100% last night @ 10.25pm this morning @ 7.00am dead 0%) - they apparently had replaced the "faulty mechanical component" according to their log!  upshot is that it's now currently winging it's way back to Dublin for another months holiday no doubt before i get it back with same problem.  my only hope is that after this next failed attempt i'll get replacement phone
sudu
I have been experiencing the similar problem. It's been an year since I bought the phone and my battery life was used to be a day or so, but now it's reduced to 2-3 hours . Android OS is eating around 30% of the battery. I used to like my phone but now it **bleep**!
PS : I always force stop the apps which are not in use and keep screen brightness low and I use power saving mode.
