I just had to delete my whole dictionary because it had that many suggestions (which have been my fault, but sometimes typing has to be fast).
So I'm wondering if there is a function to delete wrong suggestions directly, while using the XPERIA-keyboard; for example keep the finger pressed on the wrong suggestion (in the suggestion bar) to delete (or modify) it? That would be a great advantage for the future usage of the dictionary. Otherwise you had to move to your "own dictionary" from the text input options, search and delete each single entry (scrolling to the "higher" letters of the alphabet is very annoying if you've a big dictionary).
Or will there be another way to realize the mentioned functionality? Maybe through an update to Jelly Bean or maybe a specific Update for Sony mobiles?
Thanks in advance!
Median
I think there is no option that you can choose what to delete from your dectionary. I will try and update you.
You can find the settings when writing a message,tap the tools and select my words.You get there all the words you introduced,and by tapping longer on one word,you get the mark and delete option.
