XPeria J no signal
ceiraawil08
XPeria J no signal
Recently I accdidently dropped my phone (XPeria J), I had the screen and digitizer replaced. The screen works great now but there is no signal at all. I have tried to connect to the computer after Sony advised me to, but it still doesn't work.
PLEASE HELP.
Thank you.
8 REPLIES 8
Cot88
Enthusiast
No video signal or 2g/3g phone signal?
Anyway if phone signal is missed try:
- Another sim card
- Check if other antennas (GPS, Wifi) work correctly
- Try to force 2g or 3g
- Try to load phone in safe mode
ceiraawil08
Tried all of your suggestions but none of them work unfortunately. What else could it be? Where is the antenna in the phone?
Cot88
Enthusiast
I don't know where is located Xperia J antenna
But the SIM is correctly recognised?
ceiraawil08
The sim card is recognised, no other problems with the phone except for the no signal.
Cot88
Enthusiast
Did you replace screen by yourself or in a Sony service center?
Issue could be caused by
- Broken motherboard
- Broken antenna
- Antenna not correctly plugged
In phone mode digit this code *#*#4636#*#* to open diagnostic menu
Select the first choice, phone information
Check if GSM service is enabled and what type of net is selected
Check at the bottom of the screen if the button is "enable phone signal" or "disable phone signal". Try to switch using this button
Text could be different, i have done a translation to english
ceiraawil08
Thanks for the reply, but it still doesn't work. Anything else I could try?
Cot88
Enthusiast
You can try to repair firmware with PC companion but in  my opinion this is a hardware issue
Your phone needs another repair
sinister123
hi there i recently replaced my own screen and i couldnt get any signal because i never put back on the little black bits of plastic on the two top corners and the bottom under the back cover but once i secured them i got my signal back hope this is of some help for you of course this is only if u replaced it yourself
