Hello people,
I just recently got Xperia J and found out that my accelerometer (or some meter thingy) isn't correct.
For the first time i noticed this problem in an app (pics below)
i also get acceleration test (pics below)
If You run an accelerometer game Such as Temple Run , and Place the phone on a flat area , it is Probable that the man go to left or right instead of stright . test this and say what happened.
In a flat Area . Just see the horizental lines that thay are not exactly horizental.
And this is phone test
See also the link below: Xperia P also have the same problem
Please Help
where are you SONY ?
I think this can be a problem with COMPAS also
See pics of compas test below
On a flat Area
see Roll and Pitch parameters that should be zero in flat areas
My device pitch is -1 till -2 and roll is -3.5 till -4.5 in often cases
Sony plz Helpppppppppppppppppppppppp
First make sure that there are no other electronics nearby when testing this. If you still have the same problem then, send me a PM with the following information and i'll forward this for further investigation:
Name:
Phone nr:
E-mail:
Country:
Operator:
IMEI nr:
Build number:
I got some information from the project and the values you're seeing are normal and within tolerance.
See the pics . Is this normal ?! Is this Sony's normal ?!
Every body can see that this is not normal. Please give me an app that can be tolerate the sensor with that.
Thanks a lot
