Hello All devs
I was trying to flash a custom kernel from XDAdevs and it bricked the phone.
It does not turn on, this is what it is doing and what i have tried.
phone light indicator goes red when i connect it to a charger or computer, after a moment Sony logo appears for few seconds then it restarts quickly and shows sony again it does that like 6 or 7 times then it stays in a Blank black screen and stays there...
I am not able to get it in fastboot or flashmode, i cannot turn the cellphone on, or do a soft reset.
When i press power +vol up it does not do anything i tried also power+vol up as well for 1 minute.
Does anyone have a software to fix this phone? it was only about 2 weeks old. it was bootloader unlocked.
Please if anyone can help let me know, i have tried everything
try this
connect your phone to the wall charger > press and hold power & volume up for 8 seconds > let it charge for 1hr > after 1hr repair it with SUS or PCC
btw did you unlocked the bootloader?
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
UNRELATED topic, if you have some time please check this thread
or flashtool
http://talk.sonymobile.com/thread/41609
or SUS
Update Service (SUS)
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Yes the bootloader is unlocked, i tried SEUS but it never recognizes the phone
Flashtool recognizes the phone when it starts the bootlooping
this is what it shows
29/037/2012 16:37:56 - INFO - Device connected with USB debugging off
29/037/2012 16:37:56 - INFO - For 2011 devices line, be sure you are not in MTP mode
29/038/2012 16:38:01 - INFO - Device disconnected
29/038/2012 16:38:07 - INFO - Device connected with USB debugging off
29/038/2012 16:38:07 - INFO - For 2011 devices line, be sure you are not in MTP mode
29/038/2012 16:38:13 - INFO - Device disconnected
While it does the boot loop i tried pressing vol down or vol up button to see if i get the fastboot or flashmode option but it does not do that
i know that warranty was lost because of unlocking bootloader but if i cannot fix the phone is there a way to send it to sony and pay for its fix?
I got this phone from Ebay about 2 weeks ago brand new unlocked
you are probably missing the drivers on your PC
install SUS > restart your PC > run SUS then try again with flashtool
Thanks man, i was able to fix it
What i had to do is after the bootlooping i had to press power +vol up as you said until first vibration
after that i had to be very quickly, i had to connect phone to the computer and press vol up or vol down depending if i wanted fastboot or flashmode.
The trick was to do that very fast, if you are one second late you will got get it.
Thanks all for all your support! it was a guy having same issue in XDA he told me exactly what he did and it worked.
anytime
Hello all,
Im having the same problem like this. I gonna discribe my phone's status right now.
And phone light indicator doesnt go red when i connect it to a charger or computer, infact nothing happens at all.
I tried the menthod you mentioned above but didnt help because phone light indicator doesnt go green or blue when i do as it says.
Please tell me how to fix it. Ive tried many thing but.....:smileysad:
I HAVE THE SAME PROBLEM AS ABOVE.
I AM UNABLE TO CONNECT IN FLASH MODE OR FASTBOOT MODE.
WHENVER I CONNECT IT TO PC WITH VOLUME UP/DOWN BUTTONS PRESSED RED LED GOES ON. NO BLUE OR GREEN LED.
PLEASE HELP!!!!!!
Hey Man,
Facing the same issue.Tried pressing volume up + power during boot loop then connected to the PC.But it vibrates once and again it enters boot loop..
Need Help!!
