i purchased xperia E few days ago. i love the walkman app, but there seems to be a bug with the sound enhancement for headphone. with the surround activated, i am experiencing some random glitch from the music. i don't know the technical terms for this, the music randomly pauses for a second and then continues with slight crackling sound, it happen every once in a while (about every 15-30 sec intervals).
fully charged battery, music file is mp3s between 190-320kbps, no other apps running, music folder is located on extension sd card. i've tried using 2 different headphones, rebooting, even resetting to factory setting, but still having the same problems. i've search this forum but found no solutions.
i love the sound enhancement feature, it realy makes the music more enjoyable,
please fix this issue
Have you tried an update/repair?
To repair the phone software
1. Install PC Companion on a Windows PC from Support
2. Turn on the phone, and connect it to the PC using a USB cable.
3. In PC Companion, under Support Zone and click Start.
4. Under Phone Software Update, click Start.
5. Click repair phone.
6. Follow the on-screen instructions.
hi,
thank you for your assistance.
i have updated the software just as you told me, but still having same problems.
and i just discovered that the problem only persist when the screen goes out, i ve tried a couple of song while keeping the screen on and there seems to be no problem.
please look into this, thank you very much
Do you have any task killers or third party battery saving applications installed on your phone?
no. the phone is completely fresh (since the update).
are there any recommendation for task killers/battery saving app (related to my problems)?
same problem here is there a sulition to using the enhancement feature .
Unfortunately as unlikely at it seems there may be an underlying hardware issue given what you have tried up to this point. With this being the case I would advise you contact your local Xperia Care team to arrange to have it assessed by an authorised repair agent.
even m hving dis problem after update
Please send me a PM with the following information and i'll forward this for further investigation:
Name:
Phone nr:
E-mail:
Country:
Operator:
IMEI nr:
Build number:
but there is no prob with ics i think there is problem with the walkman app update given in the JB update to e dual so i guess there in no prob in hardware
