i could not find any music files in the SD card and internal memory also to set the ringtone.
every time if i want to change the ringtone through settings, it shows default ringtones only.
please help me to enjoy the different music ring tones.
hope i will get the solution from team.
Go to Settings-->Sound-->Phone ringtone and then scroll down to see the 'Music library' option at the bottom. It will open your music library as is seen in the walkman application. You can select your music file to set as ringtone.
