Sony Xperia M C1905 wont turn on!
My sony xperia m C1905 Wont turn on, i plug it into a wall charger and goes to battery screen then turns straight off, amber led stays on, i have tried to link it up to pc companion and it wont recognize my phone, i have tried holding power button and volume buttons but still does not turn on and i can not get my IMEI number to send it in to get repaired.
Someone please help.
@Phy if the device doesn't turn on,he won't be able to use that code. But the first suggestion is better.
Hi @iiaMMartyn
Connect your device to a wall charger and then press and hold power & volume up for more than 10 seconds. Let it charge for 2
to 3 hours, even if it doesn't seem to be charging. I would also try to get another battery from a same device to replace, and see if it turns on after charging..
I hope can be useful.
Best Regards.
