Xperia c wifi problem
Xperia_c_wifi_p
I had xperia c and i have wifi problem..
every time i switch it on .. it is switching off .. i restart it it but not solved ...i reset the mobile to factory but still thas issue .
What shall i do ?
2 REPLIES 2
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Jake-SonyXperia
Hi Xperia_c_wifi_prob,
Welcome to the community,
If the problem persists after the software repair, I would suggest contacting Sony Mobile Customer Care, they should be able to help.
Use my signature to find contact details if needed.
