To make a repair of the phones software using Bridge for Mac, select Phone -> Repair phone and then follow the instructions from the software. Before connecting the phone with vol- pressed as instructed by Bridge for Mac, force a shutdown of the phone so that it's turned off when you connect it.
But if this doesn't work or solve the issue you need to contact a service location or local Sony Xperia support to have the phone repaired/replaced.
yes i only have Mac.
How to turn it off? What button should I click or press or push?
I'll try everything you mentioned. I'll get back to you once Im done.
Thank you...
Where do I find the repair phone?
This is how to force shut down.I do not have MAC,so I really do not know where the phone appears.It should be visible in the phone list as Xperia C 2304 or 2305.
The Smae issue for me. Did you find solution.
My set also have same problem. Mobile operates well but the screen get flicker while you zoom the picture. I have reset the phone also. But the problem is not solved. Please suggest other option
sony xperia is the worst phone i have ever had. ....2 days after i bought sony xperia C3 all of sudden its screen got black...phone was switched on...but nothing was displayed on the phone screen....i removed my SD card and sim card also to check wheather it was working or not...but still the problem was not solved....whenever i switched it on...everytime screen was flickering and after some time it all went black.....this whole crap i expirenced..and hoping from the company that it may replace my phone or suggest me something else....i'll appriciate if company will reply to this complaint....and i'll be thankful...
