Xperia Arc S Power Problem
Stu
My Xperia Arc has been causing me problems recently....
If I fully charge to 100%, the battery will last 4 hourts maybe with minimal/no use. Even when switched off, the battery is draining.
However, I took the battery out last night after charging. I have put the battery back into the phone this morning, and it is fine!
What is causing the battery to drain like this?
3 REPLIES 3
Probably an app acting up
Repair your phone with
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
Stu
Thanks for your reply uliwooly.
I have already tried that via PC Companion and update service, but still it is the same.
Then its probably a hardware issue, you will have to stop by a Sony repair center
