X8 Problems- Please help
Well, I've noticed a couple problems. Firstly, with the on screen keyboard. I can't seem to be able to find a way to delete words that I've added as I typed, or misspelled words that automatically added. There's no way in the settings, and I've fiddled through everything. Any way to delete words?
Second, still to do with the keyboard. A lot of times, the period button and a couple others don't respond very well, but only at certain random times. How can I fix this?
Finally, it seems that this is a hardware issue, and I'm not sure if it's a problem or a nitpick more than anything else. However, when I turn the device, I can see backlight bleeding from almost all sides, but it's the left side and the top where it's noticeable. It looks like the screens not in right, and the light streams through part of the plastic where there's a crack. Should I do something about this?
Thanks.
11 REPLIES 11
Johan
To change keyboard layout you open a text message and tap on the text field. Then tap and hold on the text filed (Gives you a pop-up menu) Select input method, now select the keyboard you would like to use.
I just wanted to add that on my SIM FREE/UNBRANDED Xperia Neo i had to go to...
Menu > Settings > Applications > Manage applications > All > International Keyboard > Clear data and this cleared the learned words that i had picked up.
Please note that this also defaulted my keyboard to Japanese for some reason even though it was set as English in the settings.
I had to long press the text input box while writing a message and select "Input method" to return back to International Keyboard.
Hope this helps anyone else wanting to delete words from the T9 predictive text that the Xperia has learned.
