I bought an xperia Sp last week . My current OS is android 4.1.2 . when i put my phone on charge , the battery parcentage goes down instead of going up . Example : if i start charging when my cell has 20% charge, few mins later it appears that i have only 15 % charge . but after restarting phone , it shows the true charge level. Please help me
Force restart(power button+vol up until the phone vibrates).After that,it should improve.
power button+vol up doesn't work on SP
It must work,as long as the battery is non removable.
@alexdon wrote:It must work,as long as the battery is non removable.
There is no SP with removable battery.
Power button+volume up does not work on SP, it was also mentioned somewhere else in the forum.
Ok,sorry I did not know.So how do you reset SP?Does it have a reset button somewhere?
You can perform Hard Reset.
All you need to do is:
1)Open the backcover
2)Take a pen or pencil(not too sharp) and poke it to the pink hole at the bottom of the Xperia SP's back.Press it for 5 seconds and then restart in as usual.
Problem should solve.If condition persist,just perform a repair with Sony Update Service(SUS)
download it from here:
Then share it whether it works or not
PS:I own an Xperia SP
