Hi guys my phone won't charge while switched off. It has to be powered on...is this an issue? I hate leaving it switched on while charging...
Any help? Thanks.
yes it sems to be a issue with your phone since it's supposto charge whille it's off and on.
Yepp, it's definately an error. Have you tried any other chargers to see if the problem persists?
Before it used to charge normally while switched off.
It started doing this (not charging while switched off) when I accidentally drained all the battery down to 0% like a month ago.
Can it be solved?
Any help?
