WiFi randomly dropping
hmart
The WiFi drops connection randomly. The connection appears connected but it does not work. It have years since these problem first appeard but never get resolved. The only solution is to disconnect and reconnect the phone or just disconnect the WiFi and use data carrier connection. Does anybody found a solution??
xavinux
Enthusiast
Hi @hmart
Please, check if this issue happens also with other devices or only with your Xperia.
I also suggest boot your device into safe mode and check if this issue persists:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U34800
If everything works ok in this mode, third party app its creating this issue.
I'm at disposal for any question.
Best Regards,
