Wifi problems
maybeadam
Wifi problems
Hi i have Xperia E3 D2203 and i have wifi problems... i connect to my Wifi and after 5-10 minutes phone disconnect from Wifi. Then i must turn on mobile data and wait 3-5 minutes until phone gets connected. But signal again drop. i have router 5 metres from me so distance is not problem . Please help me ... Thank you in advance Slightly_smiling_Face
11 REPLIES 11
profile.country.US.title
Qatrium
Test your phone with other WiFi connections, and also test if other phones/laptops get disconnected from your router and report back.
maybeadam
Thank you for reply! On other devices (PC,Laptops,and other android phones) phone still connect for a minute or two and then disconnect... I tried factory reset on phone and router but no luck. Btw on other WiFi connections same ...
xavinux
Enthusiast
Hi @maybeadam
First I suggest doing a backup of your device information: How to backup?
Then try to repair your device using PC Companion.
I hope can be useful.
Best Regards,
maybeadam
Thanks for reply! But nothing help... I tried it but no luck. I tried many roms like Nitrogen some AOSP and CM12 but same thing.
xavinux
Enthusiast
Hi @maybeadam
What happen with other devices? For example, if you connect a Laptop or another Android device via wifi, they also lost connection after a few minutes?
Best Regards,
maybeadam
No, they works good but only my phone losts connection.
xavinux
Enthusiast
Hi @@maybeadam
So after doing a backup of your device information, have you also try to update your device to the last OS? Which version of Android are your Xperia device running ?
Best Regards,
maybeadam
Yes, i have 4.4.4 18.5.C.0.19. I tried to downgrade to 18.4.C.2.12. But same problem
xavinux
Enthusiast
Hi @maybeadam
I think could be a hardware issue. I would consider in this case contacting a Sony service at:
I'm at disposal for any question.
Best Regards,
