Since updating to 4.3, I'm unable to connect to Wifi when a Bluetooth headset is connected. When I go to Wi-fi settings it tells me that the network I wish to connect to is not in range even though I'm in the same room with the wireless router. As soon as I turn BT off or disconnect the BT accessory, Wi-fi reconnects.
One other thing is that, twice, my phone has turned itself off while on the charger. This is a problem as I use the alarm on my phone so it could have unpleasant implications. I heard this was an issue in the leaked version but assumed it would be resolved in the release version of the firmware.
Lastly, I've noticed a volume slider but, where it is replaced by a black bar. This does, however seem related to downloaded themes as the problem goes away when I use one of the pre-installed themes. Still annoying that I can't use Triflat or Comic Pirate without this issue
Have tried reinstalling firmware (running a repair) and safe mode. Problems persist
Hi there,
Be patient and wait for the new update (9.2.A.1.199)
It will probably solve most of your problems.
http://www.ptcrb.com/vendor/complete/view_complete_request_guest.cfm?modelid=21834
Cheers.
Certainly hope so. Thanks for the response. Wasn't even aware there's another update coming. Have been off the forums for a while.
Cheers
You´re welcome.
And I have this problem with WI FI and Bluetooth, I always have to close the connection when I need one.'d Like to solve the new firmware.Nu I tried to repair.
