Hi @Shosha,
Do you get an exclamation mark next to the Wi-Fi symbol in the status bar? That would indicate that something is wrong with the connection.
If I understood you correctly, you have already tried multiple networks and the same occurs for each? Does it say that you're "Connected" to the specific network that you experience this on? Try forgetting the network and connecting again, to do so:
- Go to Settings > Wi-Fi > Press and hold on the network name > Forget network. Now try connecting again.
If it persists, try entering the Wi-Fi network manually under Settings > Wi-Fi > Menu (3 dots in the top right) > Add network > Fill out the correct settings. Does that help?
theis wifi problem started after i ubgraded my phone to marshemallow when connected to any wifi new or old wifi in the beginning start to connect then there is no internet connection after this from itself start to searche again to network and so on
now wifi in my phone is useless at all since i upgrad it on may 2016
please help me
@Shosha have you tried what I suggested in my previous reply? It is a good start, please try that and report back with the results.
