WiFi problem
akul
WiFi problem
I have WiFi problem after upgrading my z2 to lollipop. I can open WiFi connection, Bluetooth connection, can't run Hotspot also? What should I do? Guys plz help me...
5 REPLIES 5
akul
Sorry.... Some spelling mistakes there... I can't open WiFi, Bluetooth connections and Hotspot also after upgrade my z2 to lollipop. What should I do now?
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
akul
Thanks a lot
_alexdon_
Does it work now?
alexdon
