I've recently brought a S ony Xperia SL. Everything is working fine excpet for the wifi. Once i connect to my internet, I go to the browser and all it gives me is a white page. After a few min a notifications comes up saying connection timed out. All the other devices connected to the net via wifi work perfectly fine. Idk why this is happening..PLZ HELP
Hi Shussaini,
you need to check your wifi router settings coz in some router it will be limited for number of connections, and check whether your router is dynamic or static ip config, if static ip then you need to provide the ip details in your mobile.
Regards,
Vivian Andrew
