Hi all,
After updating my Xperia Z (C6603) to build number 10.4.1.B.0.101 I've been having connection issues with every Wi-Fi network.
I've checked the forum but I only found problems about people having Wi-Fi issues with their smartwatch, I do not own a smart watch this is just a general networking issues.
Here's the problem in detail:
When having no Wi-Fi switched on while booting the phone the phone will start without any issues, I will receive my 3G/4G signal and I can browse, e-mail, everything.
Once I switch on Wi-Fi it will start connecting to previously stored Wi-Fi access points but will not connect. Eventually it says that there was a problem with connecting, even though this will take several minutes.
I can go into the Wi-Fi settings, select a different Wi-Fi network (if it is in range) and press connect, however the settings app will freeze at that point and eventually I'll get a notification that the settings app has stopped working.
I have found a "work-around": I switch the Wi-Fi to on, power off the phone and power on again. Now the Wi-Fi connection immediately powers on without an issue once the phone has completely booted, it also will connect to the default Wi-Fi connection that is in range. A different issue appears however once I move out of Wi-Fi range, it will no longer pick up my 3G/4G signal. It is also impossible to switch off Wi-Fi or switch Wi-Fi network connections without rebooting the phone.
As I said before this happened to me after updating to version 10.4.1.B.0.101 after having it received through OTA update. I do not have root access on my phone either so this can't be it.
Is there anyone experiencing the same issues? Is this somehow related to the issues people are experiencing with their smart watch connections (as seen in this topic: http://talk.sonymobile.com/t5/Software-Updates/wifi-problem-after-4-3-update-on-xperia-z/td-p/490591...
If there's anyone who is experiencing the same issues, or has found a fix for this I'd gladly hear from you.
Regards,
Danny
Sony Xperia Z
Modelnumber: C6603
Android version: 4.3
Kernal version: 3.4.0-ge09aff8
Build number: 10.4.1.B.0.101
