Our phones that supports screen mirroring uses Miracast and therefore, your TV must be Miracast certified:
http://support.sonymobile.com/global-en/xperiam4aqua/userguide/Mirroring-the-screen-of-your-device-w...
Which TV model do you have and have you also tried to update the firmware in it?
I have an LG 42ln575v-ze and is all up to date the tv will find the phone but nothing will show on the phone to accept connection
If I understand you correctly, you're going via the TV settings to connect via Miracast? Could you try to connect from the phone instead? This can be done via Settings > Xperia Connectivity > Screen mirroring > Tap Start and your TV should appear.
