This morning, when i woke up, ive noticed my phone couldnt connect anymore to wifi... I can turn it on but when i go back , the button is again at wifi off ...
Yesterday evening everything was fine, never had a problem before with my wifi connection. Please i hope somebody can help, cause i'm really upset by this... Latest time, i had several problems , i already had to buy a new one a month ago, and now this again
Did you try to:
- restart or reset your router?
- restart your phone?
- connect to a different WiFi network?
router is fine, my friends phone and my tab are both perfectly connected with our wifi...
restarted phone, even putted it back to fabric settings... Cant connect because when i switch on the button , it automatically switches off again .
I ve had this kind of message a few minutes ago: IU system doesnt correspond , do you want to wait or close ? ( or something like that -)
Might be a system crash, you may perform a software repair using PC Companion after taking a backup of your data stored on internal memory.
If you followed the guide of software repair using PC Companion perfectly and it didn't help, then you should contact your Local support as soon as possible and get your phone examined by a professional.
Sounds exactly like the issue I've had - the wifi will either not switch on at all, or will not find anything when it does switch on (which is very rare).
And then, when it does switch on I can't switch it back off again so it's constantly searching for a signal!
I've sent it back for repair twice now as it's still under warranty but it's just been sent back to me with the same issue. It's incredibly frustrating.
Not a huge help, I know, but you're not alone with this issue at least.
Interesting - hadn't thought to try that. Nope, it wont, I just get "Request Failed"
