WiFi calling won't work
Bluedog
Have z5 compact. Despite being connected to WiFi and WiFi calling setting on I get a message saying mobile network not available connect to a WiFi network when I try to make a call at home with poor mobile signal. This is a replacement phone, yet still same fault.
7 REPLIES 7
@Bluedog
Is your device supported by your network/carrier?
Bluedog
Yes I got it from ee and have enabled WiFi calling with them
@Bluedog
You should contact them to make sure that it is activated
Bluedog
Yes have done that and it is and they have sent replacement phone which still does not work
@Bluedog
Perhaps they sent you a defective phone.
Bluedog
That would be 2 detectives phones then, the first one and the replacement
YoGem
Leader
I won't be surprised that the features is not enabled in your line, can you ask them to verify the line and the account to check if it's active and everything is working fine? You can ask them to initiate a test call.
It can be also that your wifi router is blocking ports used to do voip, did you try a different wifi router?
