wifi battery drain issue after MM update to 6.0.1
elchhome
Hi folks,
I noticed a battery drainage since the MM update.
The Battery statistics shows wifi as highest consumer with 68% and display only about 10%.
I already set the wifi connection to be "off" during standby, but it seems to be always active.
The drainage is gone when the device is in flight mode during the night.
Any idea how to change this without manually switching wifi on/off all day?
Thx, Andi
4 REPLIES 4
@elchhome
most likely a third party app causing this, boot in >>> safe mode for few hours and check again.
valyo_bg
New
Problem is with Google Play Services, to avoid draining of battery in settings-location choose option "device only". WiFi scanning should be OFF (tree dots on right upper corner). This is a bug from Marshmallow - there is plenty of post's about draining of battery after update to Android 6.
elchhome
Thanks for the hints. I'll try that and give feedback soon
valyo_bg
New
And in settings, tree dots, wifi settings, keep wifi on during sleep set to NEVER. Also turn OFF network notification on same place (for open networks).
