WIFI and Blutooth doesn't work well
I purchase Jabra BT3030 Wireless Music and Calls, music doesn't play when WIFI is active/on. When WIFI is off/deactivated, music plays. I think this a sofware issue if not hardware.
8 REPLIES 8
Rocco1
I had he same problem with my jabra headset. Would connect with bluetooth but never with Wi-Fi.
i can't suf web by wifi, i don't know what wrong, how can i set up wifi
Th's why I use SE BT headsets with SE phones, Samsung with Samsung's, etc. Some of these thrid parties hardware don't work as well.
first you need to find WIFI hot-spot, if public its easy, but if requires WIFI-WPA2 key, then you should ask for it.
To setup WIFI, goto "Settings"
tap->Wireless controls
tap-> WiFi (on/off)
tap->Wi-fi settings (it should show you the available WI-FI access point information.
wierd, becuase it defeats the multi tasking functionality. You can listen to your music via bluetooth headset, but can't use Wifi. If you turn-on Wifi, music stops for unknown reason.
not a major functionality though but worth looking into and should be include on next adriod update. right?
but that's not cost effective. i bought Jabra becuase i can use it also with my Blackberry. I believe jabra is a product neutral type... oh well.
small issue but still SE must look at it. peace!
This is not the fault of Jabra or any third party BT manufacturer. It is the way brands make their customers buy catchment goods. I used to pair my SE BT with other phones like Samsung, LG and Nokia, but I soon realize they don't work as well as they do with the SE handsets.
It's unusual but not impossible.
