Whatsapp issue
shravani_31
Whatsapp issue
I'm not able to verify my number on whatsapp, it shows please connect to internet or reboot.
My phone is connected to internet with full range, i'm facing this problem consistantly and its very irritating.
My phone is just month old. Please suggest a solution. Slightly_frowning_Face
3 REPLIES 3
Danial-mach1
Leader
Go to setting>apps>find whatsapp clear cache and data then reset phone..if it dont work try to download and install latest version
how slow is your internet connection? test it with speedtest.net
Sam
Legend
Legend
Both of the above answers are worth testing; however I would also check to ensure you are running Internet and not WAP settings. The easy way to confirm this is to connect to Wi-Fi function and see if you get the same problem.
What are your thoughts about this forum? Let us know by doing this short survey.
