Whatsapp issue
djdhaval18
Whatsapp issue
I have xperia z and facing couple of issues like below,
  • whatsapp is not running properly
  • Google+ Messanger not working
  • G Talk not working
Can you please give me some solutions.
Note:
No internet issue because all other apps running successfully.
Regards
4 REPLIES 4
nick_222kail
All other apps running successfully may not mean that it will not be a problem with you connection. If you  are using packet data connection, the setting can cause the problem. If you are using wifi, I dont know.. 😐
Try changing the connetion once, I dont know how much relevent is my replay, but trying wont hurt, ryt?? Winking_Face
And try to get a proper internet setting from the operator.. Cz Ive faced a problem like this once.. Whatsapp was not workin in my old fon, well I changed my connection...
Hav a great time... Winking_Face
djdhaval18
Thanks nick for concern and help me...but I must say there is no issue in internet because it works fine.
is anybody having same issue with xperia z?
raman22179
well i have whtsapp n viber installed n they r working fine never had any problem so far
just try to install again might helo Slightly_smiling_Face
Rickard
This is most likely a problem with your internet connection. Even if other apps are working some ports or protocols may be blocked/unsupported by the operator or your router if using WiFi.
If using mobile network i would start with removing the proxy/port from the operators internet settings under Settings -> More -> Mobile networks -> Access Point Names.
If using WiFi, try disabling the firewall in your router.
