My phone had to be serviced due to faulty mic. After getting it back from the service center I did a restore and now the weather widget does not seem to be working. It is unable to set location. I tried setting it manually. It says location not found. Even with the GPS on and using the option of 'use my location' it is not able to set the location. Any suggestions? I tried searchin in the update center if the widget can be reinstalled. However, I could not find it in the update center.
Please help.
Thanks!
How accurate is your GPS? do you have stamina mode on?
Stamina mode is off. GPS is fine. IT is not even updating location manually
If you open the maps app can it find you?
