Hi sony ..i have aproblem...i test my xperia v for water resist..every thing was good except that I found water drups under back cover ..above the battery and below arround the spekar and camera..is that normal? Or there is aproblem in my phone?! What is your suggest about the problem?
Well, you shouldn't find water there. I'd recommend that you send it in to a service center so they can take a look at it.
Contact your local Xperia Support for more information:
It's quite normal since the rubber bucking meant to keep water out is mounted around the battery compartment. Thus, the whole of the back cover isn't watertight. Supposedly the components outside of the rubber bucking are not sensitive to moist.
I had the same problem... but i have ne policy, i only test waterproff when a accident happen : )
