Water has entered my Xperia Z
afzaljd
tday my xperia z accidntly drpd to river ,after tht phne brghtness is less and cant see anythg ,and my two cmares are coverd with waterdrops ,wat i do any suggestions???
Topic edited by Rickard
5 REPLIES 5
suyogpatil
Umm the best option would be open all flaps of your phone and put your phone in bowl of rice for 24-48 hrs so that all moisture will be absorb by rice.. Also dont try to switch on your phone cause that may lead to damage to your motherboard...
If this doesn't help then the only option for you may be to take your phone to sony service centre where your phone can be inspect by sony agent.
BTW what is the status of water indicator?? is it red/pink or still white??
Don't Forget to press Kudos If you find any post helpful.
Mark posts that answers the topic as Accepted Solution.
That's the best option, instead of a bowl perhaps a fabric so there's an airflow, when you take it to a Sony repair center, request a vacuum test.
Rahulsurabhi
My XPERIA Z entered water. phone is working. But back camera full cover water drops.. What can I do???. Water indicator pink..
expectromementr
I have a problem too
Water entered into one of the falps and the indicator turned red....now at the service center the r not agreeing to update my experia.... Thry told me that your phone wont switch on if u update ur phone....but my phone is working fine now.... I want to update it....so is it safe to update it?????
@expectromementrum
you should let the phone dry for a day or two in a bowl with rice
