I have xperia SP c5303. My phone screen is locked on emergency call and showing warning alarm on top. No applications are being shown. Even I have restart my mobile.
Hi, J-S
Do you have any form of Antivirus software on the handset? As this could be a lock related to it.
I faced this problem after 3 to 4 hour of use. I have purchsed new one.
No antiwirus installed.
I used option of IMEI which i think ask me for sending option and send it. After that I put it off and when I turned it ON, it shows an emergency call screen and an alarm on upper task bar.
Is it possible to take a screenshot of this? this will help us determine the best option to resolve this issue.
Please check it.
It seems the device has been locked, this would indicate that a PIN or password has been added to the device.
When you pull the notification bar down, what does it say beside the Yellow ! mark?
Notification Bar doesn't get down or up.
Only it get slide left/right but shows only camera option by doing so.
Please respond.......How can I get rid of this problem?
You don't have the PIN code?
You said your phone is new. Did you get the PIN with the SIM card?
I was already using SIM card in other mobile but issue is that PIN code option is not being shown on mobile.
