hi everyone i have a sony xperia ion and the problem is this ,that walkman of my cell stops automatically , either i am surfing net while listening songs or sometimes without doing anything else it stops !!
thank you & regards
How about
Settings > apps > all > walkman > clear everything
Thanks but it is'nt changing anything still happens the same!!!!
Try to use phone without SD card inserted and tell us if issue is the same
Thanks for your suggestion but i have already unmounted sd card but still i am facing same problem.
I have same problem. Since from ICS for arc S (LT18i) and continue in ICS and also JB for ion (LT28h).
Terrible!
Any response?
What if you start the phone in safe mode? Do you experience the same problem?
@Marian Have you tried to remove the SD card from the phone and trying it without for a while?
Hi Alexander.
If I had Xperia arc S (LT18i) with ICS, I tried use it with and without SD card. Now I have Xperia ion (LT28h) and it have same problem. Because it have more internal storage, I don´t use memory card.
