i cant understand why when i browse walkamn alwats stops playing and stays there on the status bar ! when i go to walkman the song goes from the begging or from the last song i pressed pause !
Hi Theliako
Many background processes on phone will cause freezing the musiq during playing, due to lack of RAM support
>so if you not using any other apps then try to stop the processes so that , phone will be able to work smoothly
>settings -> apps -> running -> you can see list of apps currently running, select those apps which you are not using it(not the apps which came along the phone) then stop the process
>this might do trick as well, if you have chrome app installed on phone then try to remove update of that or remove the app completely then use it
Manjuboyz
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks
well i have 430 mb of ram ! its plenty and no apps are in background ! well in 4.3 is this problem being resolved ??
Hi Theliako
then why dont you try to repair the phone once again??? any software glitches would fix after doing it, try once
Manjuboyz
NOTE:
