http://www.forummobiles.com/topic/229150-vivaz-hack/
Anyone happen to understand French? (at least I think it's french, I don't know, my apologies if it's not)
I'd give it a shot if I knew wtf they're saying.
Hello! I know basic french and i took a look at the forum you've posted.Unfortunately, the autohr of the thread has opening discussion is it possible to install Hellox2 on Vivaz.It is written that Hellox2 are installed to the stage where you have to install the last file ActiveFileSystemX.They didn't manage to install it.
I found a very interesting info there too.They are discussing that the OLD firmware of Satio,respectively Vivaz is HACKABLE !But from SE has disabled this only in the newest firmware.So, it is pointed that if you manage to debrand your Vivaz/Satio - you could succesfully install Hellox2 on your phone.
I hope this will help you!
you can use Google Translate, if you download google chrome it will ask you if you want to translate all the websites you visit
Hello all Forummobiliens / Forummobiliennes!
New from the world of SE, I just had my Vivaz for less than a week and I was surprised he was still not hacked.
By hacked
I mean that the phone would deal more signatures / certificates.
So I created this in the hope of a hack this functional Sony Ericsson.
I will describe some tests I could perform, in order to lose as little time as possible to all hackers out of the corner!
Vivaz being in S60v5, my first thought was (stupidly) thatHelloOX 2
would fit the bill. I was far from reality!
Vivaz is not supported (not supported yet we should say).
I tried to find out why, with some limited knowledge I have.
Once signed, it installs successfully, but at the opening of the latter, it proceeds to the mapping (creation of virtual disks), with success, and then decompresses the files on drive c: \ (ram the phone). Step raises concerns, decompression does not occur.
So I decided to go further and see what files the problem posed.
In c: \ HelloOX, there are 5 files:
Three. Zip are the culprits, so I have unzipped pc, then transferred back to their original place, and I deleted the 3. Zip naturally.
Once done, restart HelloOX 2 should reprogram the mapping + note that the files are already extracted.
This is actually the case. But it followed a pretty mistake!
Not dwell on that failure, I also say that HelloOx2 <<n'est basique> a tool> that automates the steps of the hack.
To summarize the actions HelloOx2:
1. Map the drive.
2. Unzip files on the virtual drive hacks.
3. Enable access to system folders (c: \ sys \ bin in this case).
4. Unmap the drive.
5. Install the root certificate.
6. Install ROMPatcher +.
By inference, it is blocked in step 3.
It would therefore file ActivateFileSystem.sisx
that:
-Is not suited to the directory structure Vivaz.
-Is not properly executed by HelloOX.
Knowing that the model of Sony Ericsson "Satio" (very close in terms of software Vivaz) managed to be hacked through HelloOX, I lean toward the second choice.
I therefore de-sign the file ActivateFileSystem.sisx
then resigns with my. cer &. key.
I put him back with X-plore.
I always runs under X-plore, he moved successfully.
I raise HelloOx2 always wrong.
Basically I'm here, I try to move forward with the logic ...
The problem that arises now is able to write to c: \ sys to copy / paste the files from the hack.
If anyone has an idea, a board, I'd be happy to listen!
For information, I found this: http://www.maxicep.c...ndi-361465.html
Apparently this person has hacked our beloved Vivaz.
There is an archive available on this forum, here it is, if it can help someone understand:
http://www.4shared.c...g1Gm/VIVAZ.html
I tried to do a translation Turkish ===> French via google, but as you can imagine, a word is translated in 3, even with that, it's impossible to decipher ... If someone has some knowledge of Turkish, I am also taker!
I only want to note that turkish is my tongue language and in the linke,given below there is nothing about hacking vivaz :smileyhappy:Some kind of a fake thread
Debranding Vivaz is easy as hell (I can show you if you need to know ^_^ ), I did it on mine weeks ago XD
Guess I'll give it a shot and see what happens.
Can you give us instructions please?
Of course (note to moderators: it's not specefied in any place that this is against the rules, so I assume I'm not breaking them by giving the info, if I am, just delete my post and accept my apologies).
1. Go to: C:\Program Files\Sony Ericsson\Update Service\ and delete db folder
2. Run SEUS and update your Vivaz
3A. Download the R2EA021 Generic Trade United Kingdom firmware file (latest): http://www.mediafire.com/?ttem6wuemx48b03
3B. (OPTIONAL) If you need other languages (list of languages http://www.fastgsm.com/en/sonyericsson/se/sony-ericsson-vivaz-u5/774/aviable-language-versions ), download the custom pack for R2EA023 (other languages) : http://www.4shared.com/file/247680799/f0860556/U5_debranding.html
NOTE: I used the Generic one from 3B and worked fine on mine. Others work aswell, but I haven't tested them myself.
4. Open the archive. Select the region you want to change to (delete de .bin extension of the extracted file if it has one).
5. Go to: C:\Program Files\Sony Ericsson\Update Service\db\13740270\blob_fs and sort files in ascending order. Search for a file which is about 370bytes in size (+/- 30 bytes).
6. Copy it's file NAME and rename the file which you choose in STEP 4.
7. Again go to: C:\Program Files\Sony Ericsson\Update Service\ and delete db folder
8. This is the most important step. Run SEUS and update your Vivaz. SEUS will start download firmware files. After download process will be almost complete (about 98% should do it) you need to copy file that you prepared in step 6 and confirm change. Wait until SEUS will flash firmware (like normal).
9. Turn on your Vivaz. It'll most likely give you an "incorrect setup" message (or something like that), IGNORE IT (if it doesn't go to step 10 just the same).
10. Last step. You need to update your phone 3rd time. SEUS will should detect new firmware for your Vivaz.
That's all there is to it.
Special thanks to mr. TigerCourage
NOTE: this tutorial is for Vivaz U5 (sorry for the missunderstanding)
Message was edited by: CrisR82
Great Thanks! But I can't make out some things:
1. In step 1 there is said to delete db folder, but in step 5 - to enter that very db folder
2. In step 4, the extracted file itself has .bin extension, what should I do?
3. In step 10: should I update the phone or just see if there's an update available?
Thanks in advance!
And will it work for vivaz pro?
1 - you delete the folder (don't worry, it's automatically created when you update/reinstall your firmware), it's written there in case you never used the Updater before.
2 - remove the .bin extension (so it won't have any extension) and rename it to the file (the + - 370kb one you found), and replace it when the firmware download is at 98% (overwritting the one if the db folder).
3 - Update is recommended, even if you don't recieve a "incorrect setup" error.
It says I have the latest software and there's no need to update
and the smallest file in the direction given is 1.17KB 😐
