i am not finding usb debugging mode in my xperia SP, sir/madam help me to find it.
You need to enable developer options first.Go to settings-about phone-tap on build number for 6-7 times.
I am also facing the same problem, i enabled developer options but still it is not getting detected on MTP mode(default). Its getting detected only on MSC mode. Its showing only external memory not internal memory..help Plzzz.
Do you have pc companion?It should install all the drivers you need.
Yeah, I have PCC but it also didnt detect it. Only the MSC mode is getting detected on PCC.
I got this problem only after installing 4.3...help plz
Very strange.Try to reinstall 4.3 via sony update service:
That too doesnt work'd...i will take it to sony service centre..!
@Lak
Did you check your Settings>Xperia>USB Connectivity> USB Connection Mode ?
@lak @subil
I wonder what do you do with usb debug and why you need that so hard...can you please explain for me??
