Updating issue :(
Updating issue :(
Guys please help me !! Whenever i try to update , they show me the steps to update my phone. They will ask me to disconnect my xperia arc and reconnect it through media transfer mode . But whenever i reach that step , my phone disconnects and the pc suite can't find my phone. It seems that whenever I'm in Media Transfer Mode , the suite can't detect my phone and in the end i can't update 😧 Please revert and help me guys ! Anyone !  I want the update desperately 😧
8 REPLIES 8
i had the same problem ytd...mayb u can try to restart ur computer and and the phone oso....
after i restart my phone and labtop..i connected my phone to labtop and i followed all the steps and it worked....u try and c....c can solve ur problem or not....
turn your antivirus and/or firewall off
or
restart your PC on safemode (restart then press F8)
make sure you backup everything
Backup & Restore app
Use this links to download the apk
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
also on your phone
settings -> about phone -> software update
or you can manually update your phone
this is how
http://talk.sonyericsson.com/message/108770#108770
When i try to backup the phone it says ' could not backup ' Why is this so ?
what are you using to backup?
