Just got a Xperia e5, trying to update Facebook app, downloads and verifys then start to install but then says "sorry, something went wrong please try again. Have tried with and without wifi turned off location but nothing seems to work....help
Unfortunately no joy, just keeps saying sorry something went wrong, also tried to install FB messenger and that won't install either
I wonder if the issue is that it is a pre-installed one. I know facebook removed Android integration a while ago. If you search Facebook on the Play Store, is there a seperate app you can download?
When I searched for Facebook on play store it shows app but says it is installed but needs updating, tried updating from store and still no luck, very frustrating
Stranger still is that my wife got exactly same phone today and hers updated fine
Gonna have to try tomorrow as its too late to start messing about now, will check for a solution then...thanks for everything and maybe we can sort it out soon
The last thing I can suggest is to reset the Play Store and downloads. Do this in the same way as you reset Facebook before, (Settings > Apps > Play Store/Downloads > Clear Data > Force stop).
Failing this, run a software repair using Xperia Companion.
I hope you get it sorted.
Thanks for the reply, the only problem I have is that I need messenger as well but when I try and install it in browser it won't let me do that either
