update failed
GUL
update failed
My phone failed toup date any body help me? it is showing  "unable to install or start phone software update components"
58 REPLIES 58
Edison1
ANNOUNCEMENT: UPDATE: Problems updating to ICS
We have identified the earlier issues and are working to implement the solution across all available ICS updates. This process will happen gradually beginning now.
Feel free to run your update again now to see if it is available, or wait and we will inform you here when all updates have been re-released.
-Jeff
Search and read. not that hard. stop making new threads. and or posting non sense.
They are working on it.
Same... Lithuania... I was dissapointed, till now Slightly_smiling_Face It worked , I updated it with Sony Update Service, but if it cares actually I tried to launch software without connecting phone to PC, and done everything step by step (Turned off the phone before connecting to PC)
Everything works fine Slightly_smiling_Face
I'm taking my words back Winking_Face
Thnks Sony
Message was edited by: Stranger
Edison1
Learn to read people! Technical problems doesnt get solved within a min or two. These are unexpected problems that arent part of the plan. If they can foresee the future then all the companies in the world can reach the top. Understand how the world works not everything works perfectly and flawlessly like how you wanted it to.
Grow up and if youre going to trash talk, do it else where. They are already working on it, so stop wasting everyones time scrolling down to read your junk.
pce.
god....same in Canada too....cant update!!!!:smileycry:
hellkt
I just managed to install it with the Update software (not pc companion).
Tharik
have you installed ICS update...because my update center SUS showing your phone is already up to date,,,
help.....
+1 (using IceCream now)  Update Software (not PC Companion)
Sony-Ericsson update software keeps restarting. It's in a loop. Just about two millimeters before it would've finished the update check. I had to ctrl+alt+del and end task from there.
PCC almost worked. It said that there's a new update available and started the update procedure, but then couldn't download the update files.
So no ICS here yet...
hi there!same problem i'm encountered last night, it takes almost 3hours for me for updating but still failed, all alternatives i already make including uninstalling and installing the PCC and SUS, and lot of downloads for the software of PCC and SUS i make..nothing happen...
I woke up early in the morning and tried it again and hollaaaa!its updating without any sweat..
Seems like server is down lastnight, heres what i observe..
While the update is running in your PCC, you can see the NET ICON is turning blue and arrow is running thru your laptop or PC which shows updating/downloading is on-going, after it will transfer to your phone your phone will turn blue as its transfer the update..then follow the instruction..there goes ICS is already installed....
POST you later whats the changes to my new ICS Xperia S... PATIENTS is a VIRTUE!!!!!
