update c1904 mannually to 4.3 firmware
jijan_jayan
any one plse give link for downloading 4.3 firmware for c1904 xperia m....!!
I tried hard...downloaded abt 2gb files...flashed some, still on 4.1.2..!!!!
sometimes instead of ftf got zip file...:(
plse help....i m from india..
Tags (1)
9 REPLIES 9
Andy9879
https://onedrive.live.com/?cid=78dd586e69bb71b8&id=78DD586E69BB71B8%216554
This one is 700mb. Good luck! And by any chance can you help me fix "network error" everytime a download finishes? It only happens to file greater than 100 for me.
Andy9879
Flash with Flashtool. Before flashing, backup your datas and then shut down your phone. Ready the ftf file to flash then connect your phone using USB to computer while holding volume down until you see a blink in the LED stripe of your phone. Then the file should be flashing properly.
jijan_jayan
thanks a lot...
sir I know how to flash...i flashed n got downgraded....:-D
jijan_jayan
the link u gave me shows C1905_15.4.A.1.9..
I need ftf for c1904...help
Andy9879
It'll work, C1904 have different 3G frequency as compared to C1905. They both are single sim so it should work. You can even flash dual sim version of Xperia M so this shouldn't be much of a problem. Probably the only problem u will face is fast battery drain when using 3g or something else related to 3g.
jijan_jayan
I ll try....:-) thanks
AidenPearce
Hey this firmware it's valid for Spain Region?
AidenPearce
I have the same question. Is this firmware for Spain region?
Andy9879
It should work.
