Unable to dial numbers while on another call. The number gets dialed but is not visible while on another call
Can you check if the same occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Reboot in safe mode did not work for me.
I tried dialing the number when on call (in safe mode)
Even then the numbers are not visible when dialed during on call
This is strange,I have seen the same problem with someone and in safe mode it worked fine. You could perform a software repair.
