Trouble with my bluetooth
Hi
I have a new Xperia Arc and I have had trouble connecting with my car bluetooth.  The message I get when I connect it that the security code is incorrect.  Having looked in the Arc manual, the default code is correct - please could you tell me what I should try?
I have previously connected with an old Samsung phone with no problems.
Thanks
2 REPLIES 2
you should check with your car dealer, your car might not be compatible with Android or 2.3
Hi
Just to let you know that it turned out that my car bluetooth is compatible with the phone.
I discovered that the car had already connected with 6 phones which is the maximum.  I hadn't considered this as i had only ever connected two phones - apparently someone only has to get in the car (eg a mechanic) and their phone will connect automatically.
We removed all other phones and I was able to connect straight away.
Hope that may help others at some point!
