Endless syncronization loop and reboots after software upgrade
Hello,
I had bad connection on my micro USB and sent the phone for repair. SE seems to have exchanged the connector and has also updated the software. Seems to to newer than whats available online. (that problem seems to be solved)
As usual I did manage to get double sets of contacts both in my phone and in Outlook:smileyblush:. I did then remove all duplicates and forced my oulook contacts to the phone. Now it is stuck in syncronization and first complained about too many contacts removed and now seem to complain about too many calendar items removed. It keeps doing that and reboots every 10-15 minutes.
Any suggestions to solve this?
I am not sure why it is too many, if it is too many against gmail and face book or just too many to handle...
Seems like latest software update resulted in that calendar and contacts was syncronized to my gmail acount even though I use MyPhoneExlorer to secure only local syncronization fo my work account. Aparently there is a limit on how many calendar or contacts you can erase from the gmail acount and that is wat caused the re-boots.
