Touching issue on Z3 tablet compact
Dartmouth47
Just had my Z3 tablet for a month or so, some serious touching issue
sometimes it will touch everywhere quite randomly when my finger touches the screen, i though a touching pen would help, sadly it didnt.
now im even having issue just to unlock my table cause it flies everywhere when I start to draw the pattern,  same issue with the typing, browsing etc etc, just make it unusable from time to time
13 REPLIES 13
Does it has a protective case or film?
Dartmouth47
yes it does, are you suggesting the film is what cause the problem?
Dartmouth47
Btw the room temperature seem to have some effect on this, most likely it happens when the room is warm
acutally forget about it, it just happened again, and im freezing cold right here
It could be the film
Dartmouth47
the thing is I bought the same film to be used on both the Z3 tablet and iPhone, if indeed the film is what causes this issue, it happens on Z3 but not the iPhone, it should then be recognised as a defect shouldn't it
It's not defective, perhaps a different brand
Dartmouth47
anyway, i peeled off the film and the problem still occur, and no one else seemed to have reported the same problem, guess this specific one of mine needs repair then
Sorry to hear that, contact your local Xperia Care
SHeila309
I got the problem because of the Twilight app. Reinstall and use another app, and the problem has not been back yet. Some blue filter apps can be a pain.
