I had bought Sony Xperia J a month ago and I'm facing very strange issue. The touch screen doesn't responds to the touch due to which i can't pick up the calls, can't unlock the phone using pattern. I have to make the phone forcibily reboot almost twice a day for the same.
My phone details are as follows:
Model number : ST26i
Build number 11.0.A.7.5
Android version : 4.0.4
I have also repaired the build yesterday, but again today the touch screen is not working.
I say yes it works really well. thank you so much. whold u mind if i post this solution in other pages too...??
Dhimant Rocks,
Do you have more useful apps for us to make the contact book work faster. Sony is useless. But you have saved the day
Cheers
Saif
Many thanks, now works perfect!
Before calibration even dialing a number was a hard task!
Wow! It works fine mate! Thanks for sharing this kind of information to solve this problem. Kudos!
Nothing is worry, I notice that when i use original charger(Included with the box) there is no problem with touch screen, but when i plug another charger(samsung, HTC, another sony phone charger, etc etc charger) the touch screen is misbehaving. So use only charger included with the phone (Xperia J), By my thinking the variation of the voltage is different of Xperia J Charger. USE XPERIA J CHARGER(INCLUDD IN BOX).
For Effected phone:
Just Install the below APK File (Calibrate.apk) by downloading it. Once installed just restart your phone.
Just Click on the below link:
http://forum.xda-developers.com/attachment.php?attachmentid=1595030&d=1356590148
Take care,
(Kamlesh Jain)
Dude.. this calibration apk is Awesome.. I had the same issue while typing on whatsapp.
I thought its due to Whatsapp update.. then i saw that my txt msgs are also screwed by slow type responses.
Sometimes it works smooth and sometimes it gets hanged. I formatted to factory settings and was still the same.
Thought it might be memory issue but then concluded to a touch issue.
But i tried this apk.. and its working as smooth as ever. Thanks mate.. you rock!!
I am being thick - looking at the link it is a zip file. How do you actually load it?
Hi can anyone help I am having same issue as mentioned on the posts but when I try to download the link windows cant recognise it can anyone help me?
Thanks in advance.:smileyrolleyes:
It wont install this app, no use of it...
any other calibration app? or it's just that my touch screen is worn off?
i can't do anything, it takes me 10-15 tries even to put my PIN, all in all, my xperia is practically unusable
Hello all, i too have had touchscreen problems
I dropped the phone and cracked the screen, it was fine but after a few weeks the phone stopped working, not turning on and generally nothing happening whatsoever
Had the screen replaced, turns on okay, but the touchscreen is not working at all
I've searched a few forums to aid me, tried to reset the phone to factory settings but that hasnt changed the problem, and i'm very confused about the calibrating solution
Any help would be greatly appreciated, been too long without a phone now!...
