I've bought a new xperia mini pro(sk17i) 5 days ago. since the 2nd day, i'm encountering an unbearable problem with the touch. when i listen to music for about 10 mins most of the screen doesn't work. same problem rises sometimes when i go to unlock the phone drawing patterns. when i keep the phone idle for some moments to cool down evrything goes ok. BUT the same matter happens frequently. what should i do in this regard? plz help me.it's urgent.
Message was edited by: Rupakwahid
Does your mobile heats up a lot ?
Try a sfotware repair and see if that helps.
________________________________________________________________
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
my phone's build number is 4.0.2.a.0.58 and when I connect it to my pc companion it suggesets that new version(62) is available. should I update? what are the steps? will it remove my personal data as well as the android system?
just run SUS and update your phone, don't forget to backup
