After using touch block, I can not get back to the normal screen. The mobile is totally unusable.
I can not get/handle the slider to deactivate the touch block
Even when somehow I am able to call the smallapp "touch block" and get "disable touch block" still the screen is locked and each touch is necessary to make twice (each active icon has as an edge a discontinue line around) - sometimes it selects something, but still not able to run any application.
Pls, can anybody help me? I work with this mobile and it is highly frustrating that I can not do many things at work!
Thank you.
Erik Iglesias.
I'm sorry to hear that.
I recommend that you try to restart the phone and see if that helps.
If you are unable to turn it off normally you can hold the red button next to the SIM-card for a couple of seconds and then start the phone.
