Hello! My problem is next : I havent used that Timescape app,until now. Actually, i wanted to try but i cant. Synchronized with face,pressed refresh then it says : ,,cant refresh facebook,click and try again" . and thats all. Wifi is on (Net is on), synchronized but Timescape with facebook does not work. Dont know why. Well, i can post through timescape status upgrade tough. Dont know what the problem is. it says ,,no event" and just only one non-face picture shows.
Could you help ?
Thanks
Hi g3orge.lukas
as far I concern, you need to update to Android 4.0 (ICS) & above in order to install as it seems that Android 2.3 (Gingerbread) devices cannot install APKs that are higher than level 10 SDKs...
@s.michael20
I need to clear things up...
ROOT does NOT make any significant changes to System Partition!
It merely just a new identification for the user to take control of the entire device that is beyond what normal users given...
Hence, users MAY crashed the device if they use third-party apps wrongly...
Thus, this is why SONY said it will void the warranty because they don't want the users to get into trouble as they are given what a phone functions in daily life and NOT a Hackers' life...
I guess you are currently referring to Unlock Bootloader :smileywink:...
Unlock Bootloader are different than ROOT...
It does not give you higher rights of using your phone as like ROOT does...
Unlocking bootloader allows you to flash custom ROMs (but you can also do that with ROOT too)
UB will cause the Update Center not functioning anymore (as well as playing DRM contents, eg: Music files)...
I hope that clear things up
Regards,
Trubo
hi,
i also have the same problem, facebook is not working on timescape. tell me how can i fix this problem. i search about it lot and got that. sony should need to upgrade timscape of all smartphones on urgent basis to resolve this issue.
please inform us all when it will be avaliable or how can we get it. i also want to fix this problem as soon as possible.
thanks
I have the same problem.. They say they have updated it but.. nothing has change.. still could not update on facebook.. whats wrong sony? cmon...
timescape facebook propramı çalışmıyor ve sorun hala çözülmüş değil, sony neden soruna çare bulmuyor
