Timescape facebook not refresh
petyaaa6
Hello! My problem is next : I havent used that Timescape app,until now. Actually, i wanted to try but i cant. Synchronized with face,pressed refresh then it says : ,,cant refresh facebook,click and try again" . and thats all. Wifi is on (Net is on), synchronized but Timescape with facebook does not work. Dont know why. Well, i can post  through timescape status upgrade tough. Dont know what the problem is.  it says ,,no event" and just only one non-face picture shows.
Could you help ?
Thanks
73 REPLIES 73
Prateek_Rana
I am using Xperia P build 6.1.1.B.1.75 , I recieved a notification for updating timescape when i was on previous build, i didnt installed it that time Slightly_frowning_Face
After upgrading i cant see any update in update center, i refreshed but still cant see that update for timescape.
Please suggest aimee what to do to get timescape for facebook working.
i get error " tap here to retry, cannot update from facebook"
kcredddy
i've xperia s...recently upgraded to 55....from den onwards facebuk timescape works unexpectedly...it works in some time ..and most of the time it is not working
Gokul_Bontha
I'm als facing the same issue,I amm using xperia P (updtaed to 6.1.1.B,1.75)
LibraMoon
If you can't wait for the update from Sony, u can try this, worked for me. http://talk.sonymobile.com/message/345303#345303
You only need the file EventStreamPluginFacebook.apk. Install that and you should be good.
Installed three days ago and it's still working. my handset is Xperia S Lt26i firmware 6.1.A.2.55 (southeast asia). Note that upgrading to latest .55 firmware did not resolve the Timescape Facebook issue. I had to install the Xperia AX ported app to get Timescape to work again.
MikaLilja
LINK:
http://talk.sonymobile.com/thread/109927
Timescape stop working after FB (Facebook) 2.0 update
1) Download this file
https://www.dropbox.com/s/f8oc9cg07143blu/Timescape%20AX.rar
2)From this site:
http://talk.sonymobile.com/message/336977#336977
3)Send "EventStreamPluginFacebook.apk" file to yourself via Gmail.
4)Open Gmail at your phone and install file.
5)Timescape fixed!
Tulio_Michel
Hi there,
Just wanna tell you that today i could download the update from Google Play. Everything is working just fine.
My phone is Xperia Play (GB) and my country is Brazil.
Regards,
delite
I recently viewed that TImescape Facebook Extension is updated to Feb 13, 2013, but when I try to install it on Google Play it says Installed and dont let me install it, and in my mobile the timescape FB extension is not installed.
delite
Thanks for the file, but this file is older version, i saw Sony released latest update to FB extension on Feb 13, in google play, somehow it cant be updated. Can you provide apk file for the same?
g3orge_lukas
need to root or something ? i got this message "There is a problem the parsing package"
s_michael20
@G3orge.lukas
Nope rooting can effectivly mess up render the Sony Update Centre useless and will no longer work for any fututre updates direct from the phone or via PC or Mac Sony Softwares I read that up somewhere on this forum. I can see where your coming from though if rooting means removing the current Facebook Timescape app installed and re-installing the updated one from Google Play to the Sony Miro.
The reason for this problem why you cant update the Facebook Timescape app on the Sony Miro is because it's .apk has permissions which prevents it from being removed or even updated on the phone. But for some strange reason it's saying it the current updated version in which it is not which only makes me believe Miro will be stuck with the current non functioning version of Facebook Timescape.
The only way could be that 'Sony' pushes an update for Miro and Tipo Devices to solve this issue
which I dont see it going to happen.
Target Markets for Better Phones Slightly_smiling_Face
