Timescape facebook not refresh
petyaaa6
Hello! My problem is next : I havent used that Timescape app,until now. Actually, i wanted to try but i cant. Synchronized with face,pressed refresh then it says : ,,cant refresh facebook,click and try again" . and thats all. Wifi is on (Net is on), synchronized but Timescape with facebook does not work. Dont know why. Well, i can post  through timescape status upgrade tough. Dont know what the problem is.  it says ,,no event" and just only one non-face picture shows.
Could you help ?
Thanks
73 REPLIES 73
xJokerz
I have the same probleem :'(. The only thing that is working for me is twitter and all the other extensions except facebook... I really like the timescape app hopefully there is a sollution.
petyaaa6
Ja, i tried that,and same to me. Tried Twitter and it works,but facebook still not. Its annoying  and i dont know what is going on, or why is that.
Petter
Enthusiast
Have you made sure you have the latest versions of Facebook installed in your phone?
You can check by going in to Play Store and check your list of installed apps.
petyaaa6
YEs,it is the latest version. and still not working with timescape.
Andrey_Music201
Hi, everybody! Today I have changed events' notification in Facebook and I have got the same problem with Sony Xperia Miro with Timescape : "Could not update from Facebook.Please tap here to retry".Only twitter account refreshes.
a)Deleting facebook accounts doesn't help.
b) Factory reset doesn't help too.
I think it is problem with Facebook.
1) It this problem appeared in the World since yesterday only?
2) Where can I configure sync period in Android?
Sony Support, HELP US!!!!!!!!
or I would advise to my friends buying Nokia Slightly_smiling_Face
System_Zed
Same here, i've got this prob on December 12, since only twiter is working no facebook update at all.
Using an Xperia S running ICS 4.0.4 / .50 firmware.
SONY update our Timescape Apps QUICKLY.
System_Zed
Updates...............Cheked
FB Account..........Cheked
Facebook & Cie....ReInstalled
TimeScape & Cie..ReInstalled
Clear Cache..........Done
Reboot.................Done
I Think teh Prob. is Facebook App & The Solution is a TimeScape UpDate.
Thx Petter.
lsegura
That's right, the problem is with the upgrade of Timescape on twitter if it is working properly.
Your support is important to correct this problem.
si, es correcto, este problema es con la actualizacion de timescape, en twitter  si esta funcionando correctamente.
Es importante su ayuda para corregir este problema.
rudiherwansyah
I had same problem since a view days ago.
I think this error occur because facebook has made a big change with their system (migration to HTML5) and Timescape can't connect with that.
